Vacuum advance spring
Your distributor should be a IAT-4009A, the centrifugal is 9 degrees at 2,000 RPM's. Vacuum advance is 13-3/8" of mercury, no advance, 14" 1 degree, 14-3/4" 2 degrees, 15-3/8" 3 degrees, and at 16" 3.75 degrees. Now both together come out to 12-75 degrees, which is max for that engine by manual, but you can get away with 15 degrees. Use a timing light and this will tell you which spring to use. Walt.0
The distributor has been changed from the one used in 1948 to 1950 to a 1951 through 54 model. I found this out the hard way when I ordered a new vacuum advance from Dave Kostanek and he sent me the 1AT-4009A vacuum and its arm wouldn't connect to the plate. We're in the process of exchanging vacuum advances. Does that change things, Walt?0
- 104 Hudson 1916 - 1929
- 172 The Flathead Forum
- 599 Vehicles
