Heater flow direction
GrimGreaser
Which way dies the coolant flow through the stepdown heater system? Out of the water pump port into the heater core? Or out of the head through the heater core into the pump?
Thanks.
  • J Spencer
    J Spencer Expert Adviser
    Out of the head through the heater core, return to the pump
    Jim Spencer
    WNY/Ontario chapter
  • GrimGreaser
    Thanks, just needed to confirm my thinking.
  • Do you have the Ranco valve in the firewall? If yes, then the outlet on the right side of the head goes to the right side of the Ranco valve, the left side goes to tht top of the heater core, the bottom goes to the water pump as that is what pulls the water through the heater. Walt.
  • onerare39
    edited November 2011
    will this help
