Ignition switch
super651
super651 Senior Contributor
I need a ignition switch for my 1946 Super-6.
Any help on this is a big Thank youall. Rudy
  • Ol racer
    Ol racer Senior Contributor
    Rudy,
    Is this helps, I put a Universal On/Off Ign Switch from local parts store in the originsl hole and retained the Hudson Push Starter Button. Not sure what original switch looked like though because it was missing..
    Chuck
  • Rudy, check you PM file.
  • super651
    Thank you so much Hudzilla,I sent a PM Rudy
  • Last time I needed one I took a 1948-49 switch and drilled /filled the rivots and switched the bracket and the beige bezzel. that is the onlt differance. The actual switch is the same as the 46-47,
    Roger
