side mount antenna
You may already know this, but the original-type antenna was a cable stretched back and forth between brackets mounted underneath the runningboards. Actually, I have a side-mount antenna on mine simply because I couldn't get the runningboard antenna to give me much reception, but in the end that may have been my radio's fault. Apparently they worked (after a fashion) back in '37!
Anyway, there is no repro because there was no "factory" side mount antenna to pattern it after.0 -
If you want to pm me with your contact imfo I know someone who can make you one for under your running board he used mine as a coppy for a car he was doing.0
No! I didn't know that about the factory antenna--
Always something new to learn. This cab has the holes for a side mount antenna that was installed. The other cab I have has the same side mount holes in it as well.0 -
Kdancy wrote:No! I didn't know that about the factory antenna--
Seems to me I read, probably a bulletin issued sometime in the 1930's, where you could order a vehicle with a side mount antenna - to be installed by the dealer.
Might be something in the service magazines in the online library -
http://hetclub.org/burr/lithomepage.htm - 1930-1939 Service Merchandiser section.
Alex Burr
Memphis, TN0 -
I also had a side mount antennea on my 37 coupe. I got it that way , factory radio accessory. No indication of ever having a running board antennea.
My antennea had a red ball on top that matched the hood ornament.
I always assumed it was a Hudson Accessory.
Roy0 -
I was told that the running board antennas were designed to help eliminate static generated by the overhead streetcar electric wires in the cities. Sure makes sense.0
http://cgi.ebay.com/ws/eBayISAPI.dll?ViewItem&item=280782007954&fromMakeTrack=true&ssPageName=VIP:watchlink:top:en
Here is a repro side mount one ---0 -
I HAVE SOME OF THESE IN MY PARTS I'M NOT SURE OF THE RED BALL BUT I'M SURE I HAVE THEM WITH A BLACK BALL THEY ARE $30 EACH + SHIPPING I MUST HAVE SOLD OVER 15 THIS SUMMER ALONE EAIL ME AT HUDSON1957@AOL.COMHET DROP THE HET FROM THE EMAIL ADDRESS I GUESS I SHOULD BE HAVE BEEN LISTING THEM ON EBAY DAWOONK!!!!
HUDSONLY
PAULARGETYPE0
- 115 Hudson 1916 - 1929
