Hydramatic pan bolts torque
Hello! I'm going to change the fluid on my 53 super wasp. I have the pan gasket but just to be completely sure on everything. Dex III fluid or dex/merc. Put 5qts in and start the engine and add the rest. 11qts in total with the converter drained. Thanks guys.
Zach webster
Zach webster
Sounds like you've got most of the info needed, however it probably won't quite hold 11 qts. That is for a 'dry' transmission, probably closer to 10qts. I'd put 9qts in and check it and go from there.0
- 115 Hudson 1916 - 1929
