Gearbox mounting rubber for 48 Hudson Super Six
ESSX28-1
ESSX28-1 Senior Contributor
A new member of the New Zealand HET Club is looking for a source for a new gearbox mounting rubber for his 48 Hudson Super Six. Where can I recommend he tries?
Thanks
  • Uncle Josh
    Uncle Josh Senior Contributor
    edited January 2012
    I was looking at Steele Rubber products stuff I believe and saw where they will put new rubber on your old steel.
    http://stores.ebay.com/Steele-Rubber-Products
    KGap carried them but you might check with them before you order. I'm still waiting with no word...several months now.
    Maybe Bill and Charlie's on eBay
  • Steering boxes are not mounted in rubber, they bolt directly to the frame. More info is needed on this item?? Walt.
  • ESSX28-1
    Hi Walt
    He's looking for a new gearbox mounting rubber for a 48 Hudson. Do you know a source?
    Thanks
  • drivergo2
    drivergo2 Expert Adviser
    Is it a transmision mount.?:unsure: John
  • ESSX28-1
    He described it to me as about 4" rubber square with steel bonded top & bottom (various mounting holes) & seriously needing replacing.
  • Geoff
    Geoff Senior Contributor
    Dave, these Americans cannot distinguish between a "gearbox" as we colonials call it, and a steering box. What we call a gearbox is a transmission to them. I can get a suitable alternative here for around $100. It is a generic type which can be modified to suit. I used one on Trevor's '37 T coupe.
    Geoff
  • ESSX28-1
    Thanks Geoff.
    I'll give Andrew Peterson in Papamoa your details then & you 2 can talk without me in the middle
    Dave
