'35 Hudson 8 Headlamps Wanted
StillOutThere
I would like to purchase a complete pair of '35 Hudson 8 headlamps. I am aware they were identical units on '35 Studebaker or Auburn. I bid the pair just completed on eBay but was not the winner. Any leads or suggestions?
Try Jason @ Vintage Coach, Tues. to Sat. 8am till 5pm. He may have some.0
Marconi wrote:Try Jason @ Vintage Coach, Tues. to Sat. 8am till 5pm. He may have some.
Jason did not have.0 -
WHY NOT CHECK THE STUDEBAKER FORUMS. ALSO CHECK WITH THE AUBURN GUYS. I didn't mean to yell. Sorry
Bob Hickson0 -
You might want to try Don Axelrod... he specializes in ONLY headlamps. His phone number is 781-598-0523; email is hdlthqtrs@aol.com; Located in Lynn MA
Be warned: he can be a bit of an abrasive character! :blink:
Jim0 -
Carl Weber owns a 1935 Hudson Convertible 8 and is a HET Club Member since 1961 and has 2 garages full of parts. I would give it a try. He is a gentleman! He lives in Mass. Will pm you his tel. number. Michel0
BJ__TN wrote:WHY NOT CHECK THE STUDEBAKER FORUMS. ALSO CHECK WITH THE AUBURN GUYS. I didn't mean to yell. Sorry
Bob Hickson
I DID POST in the Stude and Auburn forums the same time I posted in this forum. Had a very nice Auburn fellow inform me that the eBay auction text was incorrect. That the Auburn lamp has a different mounting - is not the same. And the Studebaker lamp is different also. He sells the Auburn lamps restored - he gives the others away on the occasions he finds them.
I'm not too old to learn and did from the Auburn guy. I need '35 Hudson 8 lamps.0 -
54SuperWasp wrote:Carl Weber owns a 1935 Hudson Convertible 8 and is a HET Club Member since 1961 and has 2 garages full of parts. I would give it a try. He is a gentleman! He lives in Mass. Will pm you his tel. number. Michel
Thanks, Michel.0 -
Hi.I have a pair of headlamps from a hudson 34/35? terreplane 8.The glass is marked (on top)BROWN STABILITE HEAD LAMP.On bottom is marked THE W BROWN MFG.CO COLUMBUS OHIO USA.The lamps are complete with brackets ,and are cromeplated.Diameter is ca. 27cm.and the lengt is ca.20cm.They have been lying in my garage for 44 years,when somebody stole the car,so it`s the only thimg I got left.Can you send me a picture of the lamp you need? Greetings from Kolbjørn.0
This is a '35 Hudson 8 car with chromed lamps. Kvitvik, I would send you a private message but that option is not available for you. Please send me a PM with your email. Thank you.0 -
The lamps that I have is not like those.the car they came from looked about like this type,but smaller rear window,4 or 5 vents(to open) in the motorhood.maybe 33-34. Kolbjørn. mail:k-kvitvi@online.no0
35 H8 headlamps were available optionally as either black or chromed?0
Hi If those lights turn out to be from a 33T-8 I would be interested in them as my 33 has the wrong headlights, with that script on the lenses I would guess that they are 33 T-8. Supposedly the lights are the same as 33 Nash but they are in fact slightly larger with different rings but i think the lenses might be the same. Sorry to be off topic but I don't have any 35 lights or i would help this cause. Mark0
bob ward wrote:35 H8 headlamps were available optionally as either black or chromed?
Depending on which model of '35 Hudson, the headlamps were either body color or they were chrome.0
- 115 Hudson 1916 - 1929
