Twin H Carb spacers
NAPA, Take an original and they can match it up with a Ford gasket0
Try felpro 60269 for a Ford just a tad under 1/8" each. I had to ream the holes a bit to place over the studs, no biggie.0
Thanks0
Rochester Monojet (GMs) or Carter YF used in MOPARS used a thick base gasket.0
I think you're looking for the backlite type spacers, you would still need 3 thin gaskets with this and the heat sheild.
Rochester Carburetors
CHEVROLET 1932-52
Throttle Body Parts
Delco 3692799
http://www.chevsofthe40s.com/shop/search.lasso?search=+3692799+&searchtype=FT&Go=Go&year=All&dept=car0
