generator condenser
hoggyrubber
hoggyrubber Expert Adviser
i finally found the part number and ordered the voltage regulator for my generator. i see it has this condenser on the outside, i thought i should try to replace it if it's not too high. does anyone know what part to get to replace it???
i don't know if the gen works or not but turns free and smooth and i oiled up the front and rear bearings. thanks for any info, stacy
  • bartibog1
    bartibog1 Expert Adviser
    the condensor shown is for supression of static on your radio.not required for generator operation. do to age of it likely not any good anway.
    steve
  • hoggyrubber
    thank you. i will worry about the static after i get a radio!
  • Marconi
    Marconi Senior Contributor
    That condenser is for reduction of generator interference in the radio. Don't worry about it 'till you have your radio in and operating. Generator interference is a loud 'scream' louder with increased engine speede. It usually sounds like a siren coming thru the radio speaker. If you need one, get a hold of me, I'm listed in the WTN as radio advisor. Steve.
  • hoggyrubber
    great, glad i don't have to worry about it! the radio is a ways off i'm afraid. :whistle: i get the wtn so, thanks, i'll get with you if need be. stacy
  • mars55
    mars55 Senior Contributor
    If you want to replace yours, here are some part numbers. The difference between these part numbers is in the connector. I am not sure if the NAPA Echlin RC1 is a Radio Suppression Condenser. NAPA calls it a Distributor Condenser.
    NAPA Echlin RC1
    NAPA Echlin RC2
    NAPA Echlin RR186
    or
    Standard Motor Products RC1
    Standard Motor Products RC2
    Standard Motor Products RC51
    or
    Borg Warner/BWD G83
    Borg Warner/BWD G137
