Hudson stepdown dual outlet exhaust man ADAPTER?
A request for an another adapter for a Hudson stepdown motor was sent to me by a previous customer. The request was made last week and the ones we have contacted to buy back an adapter havent responded or have already installed theirs.
We plan to make more in the future, but not now.
If anyone would like to sell their adapter, we will gladly furnish the contact name.
Prefer email communications at hetpbebop@gmail.comhet drop the het. Thanks, Bob P
Bump, another reply, but doesnt want to sell. If you know anyone with one not using it, but might sell, please email. Thanks, hetpbebop@gmail.comhet drophet Bob P0
Bob,
Thanks A lot for the additional Exhaust Gasket for the 7X Dual Adaptor. I cut the holes with a small tin snips and worked well. The 'Service behind the Sale' means a lot. I beveled the adapter and the two down pipes for my '37 Hudson 8 and it looks great. Next picture will be after installed.
Thanks0 -
Thanks Ol racer, hope you are enjoying your late Xmas present. Drive safely, Bob P0
Well here is the Install on my '37 Hudson Cpe Project. Rather than weld the pipes to allow some swivel,I beveled one side of the Steel Flange THen had the muffler Shop slightly 'flare out' the ends of the pipes(N/C)
The centers of both pipes required filing a flat side to the flares so they would mesh together but created a 'slight divot'.
I could have filled with Exh Sealer but elected to glue two thin Caviller Cat Converter 'Donut Gaskets' #39160 below Bob's Gasket (supplied with the neat Dual Adapter) creating a slight 'cone' for the beveled pipes to seat. I defy it to leak, but time will tell...0 -
Looks good, nice work, hope you are successful with the "stop-leak". Take a video if you can when you crank it. We would like to hear the sound. Thanks, Bob P0
Bob,
I sent you a P.M.
Jason0 -
Thanks Jason, sorry I'm late returning from the MidSouth meet. Looks like Lee has already found an adapter.
If any else needs one, suggest putting your info on the forum, seems to be an ideal place to advertise the adapter. Good luck. Bob P0
