Vintage carb kit
Wondering (hoping) someone may have an actual vintage Carter carb kit they may want to sell. Or know someone with a stash.
Its a #1045 for a 331S Carter W1.
The main reason I need it is for the correct metering rod and jet that come in it. All the other parts would probably help also.
Thanks!
Jeff
Thanks!
Jeff
Okay since that drew a blank, how about maybe someone has the extra parts I need?
The metering rod # 75-119, meter rod jet # 120-51 S and the pump jet # 48-35?
Any help would be great!
Thanks,
Jeff0 -
Jeff I have bought in the past Daytona Carb kits from Terrell Machine in Texas. been a while however0
Thanks for the lead guys!
Although most of the 'new style' kits are much better for the crappy gas they dont usually include the meter rod, meter rod jet and pump jet. I will check them out anyway tho.
I might check with Walt as well as he may have a 'stash'!
Thanks again,
Jeff0
