37 Terraplane parts
I noticed the air cleaner / silencer in one shot. Is that the regular one, or did this car have Electric Hand (with the vacuum tube connection coming out of the air silencer). Also....and you've probably done this...did you check to see if it still has the crank extension rod held by the spring clips up over the trunk lid hinges? I think this is on all the 4-door and brougham bodies. (I don't need one but didn't know if you realized it was there.)0
I see Water jacket , Trans , steering wheel .
Exhaust manifold , all good stuff.0 -
Sorry John..Carb and air cleaner were sold since pics were taken..no skirts either..0
john clarke wrote:Hello,
I'm in the market for an Air Cleaner and carb for my 37 pickup...Would the one shown here be the correct choice? I'm also looking for some fender skirts.
John,
What carb does your 37 use? I have several single throat, manual choke carbs from my 39 112. All of my Hudson manuals have been packed up so I can't look it up.
Kevin C.0 -
Hi, are the water jacket and distributor still available?
thanks in advance
Bob in Alberta0 -
sorry..just sold both
Walt here; What model is the car you need the carb for? Pick up should be model #71 and that takes a Carter W-1, one barrel #348 from serial number 250000 and up, hand choke model.0
I just happen to have a carter w1 manual choke carb on a 46 Chevy I have..will that work?0
I could use the front bumper brakets. Do you still have them?
Thanks, Jeremy0 -
Jeremy..Yes I have both front brackets in good shape.. Todd 218-208-20800
- 115 Hudson 1916 - 1929
