8 Cyl Water Pump Question
SuperDave
SuperDave Senior Contributor
The part number for a stepdown 8 water pump is 300567. The Hudson interchange manual says it fits only 48 and up. What is the difference between the two and could the early one be used on a 48 and up ?:huh:
  • Park_W
    Park_W Senior Contributor
    Dave, the interchange book says you can't use the '47 and earlier 8-cyl pump on a '48 or later, so one would assume the reverse is also true.
  • It may have to do with the fan blade hub and where its positioned on the shaft. Seems to mee the pump looks the same but maybe the radiator spacing is not?
    Roger
  • Park_W
    Dave Kostansek's out of the business now, but I bet he can tell you.
  • SuperDave
    The problem that I was presented with was...A Member has a 47 with a stepdown engine. The water pump needs replacement. Which one does he buy???
  • Might contact the 8cyl expert listed in the WTN . I've spoken to him before but dont recall his name. And I dont have a WTN handy,
    Roger
  • Geoff
    Geoff Senior Contributor
    The water pumps are interchangeable for all 8's and 6's 1936 thru 1947, and these come up regularly on ebay, so that's the way to go in my opinion. I don't have a '48-'52 pump here to compare, but they use different internals using a double row ball race instead of plain bushings. Not sure if they are the same mounting.
    Geoff
  • Park_W
    Dave, if it's a stepdown engine, he should buy the water pump for '48 ff.
  • SuperDave
    Thanks to all for all the input. I will relay it to the member..:) :)
  • SuperDave
    email..my47hudsons@yahoo.com
    Bob Harbrecht/.Fa winters,Idiana summers. tell him I sent ya,
    Thanks, Dave Waddell
  • the late one fit on my 47/thanks
  • SuperDave
    Glad you got it fixed,, See You at Dade City?
