Voltage regulator and generator wiring????
Your two posts are a little confusing. Are you dealing with an original generator or a modern alternator?0
Wiring is basic - B terminal on regulator connects to voltage from battery, "A" terminal to "A" terminal on Generator (the larger post usually), and F terminal to F on generator. There is usually a ground wire as well from the voltage regulator base to a screw on the generator body.0
- 115 Hudson 1916 - 1929
