draining timing cover on308
I am just about to begin reassembly of my motor. I asked the machine shop to put an extra drain hole in the front main cap across from original, but instead he put it very low in the cap. Question: Does chain lube depend in part on a certain depth puddle in the timing cover, or is overly efficient draining of timing cover ok?
By the way I will keep my promise of taking notes and posting pics of the build for posterity.
Dave
Dave
The chain gets oiled down the short 'troth'. The extra hole in front cap is to help drain excess oil that can 'overcome' modern timing cover seal causing a leak.
I dont think was a problem back with the original type thicker seals. The best seal to use today is National. (Dont have number tonite). Be sure turn around the Damper spacer so smoothest surface rides in the seal.0 -
Thanks, but to clarify, is there any value to accumulating some oil in the timing cover?0
That's what I figured but needed to hear from someone else. Thx Geoff! Between the trough and a 1/16 hole in the oil galley plug I should be ok for lubing chain0
Don't drill a hole in the oil gallery plug, chain gets plenty of oil front the front cam bearing. You will lose oil pressure when engine gets hot. You want to see how much oil chain gets, remove the front valve cover, set engine at 1500 RPM's and watch the hole in the front of the block that goes to the timing chain, oil comes through that hole like an open facet. The front cam bearing is set up to supply oil to the chain. That is the reason to drill another hole in the front main to help move oil out of the valve cover faster. Block that hole you drilled in the plug. Walt.0
I never drilled the hole in the pipe plug, and now that I see it is hidden behind my engine mounting plate, and hearing from all of you, I won't.
Dave0
- 115 Hudson 1916 - 1929
