NOS Trico wiper blades and arms
I have some new trico blades and arms that I had as
spares , no longer need them. ALL SOLD THANKS
11" "Rainbow" ,trico RB 11 , .Fits 1954 , but could be used on earlier stepdowns.I found a listing that shows it for 48-49.
Price is $SOLD SOLD SOLD.
Two trico arms , adjust from 7 1/2 " to 9 ".Have patent dates 1934-38.
No part numbers ,or boxes. See photos.These matched up to a Hudson
I had ,but don't remember which one.SOLD SOLD SOLD
Two 9" flat blades , has rubber flex mount.These would pair up with the adjustable arms.The rubber is like new , stored in dry area out of light.
Sold Sold Sold
Send a PM,
I take check , USPMO , Or paypal
Thanks Roy
Sold Sold Sold
Send a PM,
Thanks Roy
would these go on a 31 and could the flat blades be fitted to them
thanks
mike0 -
Will they work on a 35 terraplane pickup0
Roy
I have been trying to send you a PM. I can compose but cannot see any button to send! I am interested in the blade and arms for my '50 Pacemaker.
Alistair
NZ0 -
Mike , the book I have shows 1931 Essex takes a 6 1/4" blade and an 8 1/2 " arm.
The arms are adjustable , so the combo may Work. I don't know if your motor would pull a 9 " blade if it's still vacuum.Measure your arm and blade length total and look at the photos. The arms do fit the flat blades.I believe they will work , but you need to make the final call.I have no numbers for these.
Dterry : The chart shows 35 Terraplane closed vehicles take a 8 1/4 blade
and an 8 " arm . I would say they should work unless you have the type held
down by a nut. Again , look at the photos and measure what you have.
The arms are adjustable.
Alistar : the arms probably are not correct for Pacemaker , I believe the step down arms have an angle near the end. The 11" blade Should work ,as it is listed for that year.
To all , as best as I can tell 41-47 used a 9" blade , but to use these blades you would need these arms , as the attachment is different.
36-38 Terraplane use a 9" blade and a 7 3/8 arm , which is probably why I have these,I had a 37 Terraplane.
Hopefully you're not all completely confused.Look at the photos , compare the measurements and maybe they will work.If you need more info I will try to help.
Thanks Roy0 -
Hi Roy have an electric motor on mine and at the moment have 10'' arms and blades,These are currently model A 1s and when I drive down the road they flap like a bird LOL
I would be keen for them
how much to ship to Auckland NZ
thanks0 -
Mike , I sent a PM.
Thanks Roy0 -
Anyone else have the same problem Ernie28 described. Where you can compose a message but there is no "Send" button?
My computor has been like that for awhile. Not sure when it happened. I dont send that many private messages. If I use my cell phone it works fine so mus be with the spyware?
Roger0 -
Anyone know a solution ?
Roger0 -
Roy
I will take the 11" blade and get it sent to my sister in law in Montana who is due here next month. As I don't seem to be able to PM you can you email me at address triangle AT het DOT org DOT nz. Can pay by PayPal
Thanks
Alistair0 -
Hello Alistar , I just sent you a PM, we will see how that works.
The way I do it is to click "New Messaages" at the top of the header and
when my message page comes up there is a choice that says "Write".
If you click on that a form comes up and after you fill it with your message there is a spot at bottom that says " Submit "
This seems to be working for me. Only thing is you need to write down the " handle " of the person you want to contact, because you have to fill it in.
Hope this helps.
I will also send you an email for info.
Thanks Roy0 -
Hello Roy,
got the parts today and I am extremely happy with them they are exactly what I wanted,
should have them fitted in the next week or so
Nice to have original stuff no one going to believe how old they are LoL
Its been a pleasure
Mike0 -
Hi Mike , thanks for the feedback , glad they work for you.
I'm surprised how fast they got there, usualy takes that long across the US.
It's been a pleasure on this end also , Thanks again , Roy0 -
Hi Roy,
got them on attached with a model A drag link to make both sides work
and they will work super well, they stick to the screen that well that the screen has to be wet for them to slide
They also look way cool as well, its only a small thing but when you
have been using the spindly model A 1s that flap like a mad women going to the motorway and having to put on Rainex so you can see in the rain, a major improvement
thanks again
Mike0 -
Hello Mike , thanks for the feedback on the wipers.Thanks to the internet ,somebody on the other side of the world is happy.!
Roy0
- 104 Hudson 1916 - 1929
- 172 The Flathead Forum
- 599 Vehicles
