body fit ~ stepdowns
How finicky are folks about body/door fits on their stepdowns? I have odd gaps from doors to body, fenders to body, hood to fenders e.g. the hood hinges are bolted to the cowl without shims and the hood when closed is clearly off set to the drivers side (big gap on passenger side). There is very little "wiggle" room when mounting the fenders because of the multiple bolt points. Were the factory gaps this way?
To change that gap I believe there is slots in the mounting hood to hinge holes. This would help center hood in gap,
Roger0 -
Doug, most cars of the era did not have a good fit compared to todays cars. If your car was ever in a minor accident, shops came as close as practicable with repairs. probably due to a fender bender at some time, my passenger door is spaced a bit tighter than the driver side (coupe).This became a take from Peter to pay Paul repair. That caused the hood to be a little too close to the cowl panel & unless the hood( bonnet) was opened carefully it would chip the paint just a bit. The hood fit was even to the eye. So, I reamed open the adjustment hinge hole about a 1/16 inch. Problem solved. Patience is required to find the balance between almost perfect fit alignment and enough, but not too much, clearance.0
Some hinges had washers between the hinge and cowl. Slot the hinge also to move the hood forward, they always hit the cowl vent. BTW they were never very good from the factory on gap spacing on doors, trunk lid or hood0
I had similiar problems on mine and applied the good time consuming and patience testing suggestions you have received and still couldn't get where I wanted it. Finally when I put the front bummper on I noticed the front end was not centered on the frame. The adjusting point is the big center bolt that goes to the radiator support frame. Centering it then let me make the adjustments to get it close (not Perfect). BL0
Relief! Thanks all. Shiming the hood hinge is a possiblity. I'll check the radiator support bolt as well. My '54 coupe most likely went through what's been described.0
Its all a matter of perspective...;)
Sorry,I couldn't resist...0 -
Mine looks a little better than that, but not much. We're getting there!
I have two 54's I am working on. A sedan and Hollywood and I found the gapping was a issue. More so than on the other year Hudsons I have worked on. I guess it was last year of production and some things were not done right. On the sedan I had 3 trunk lids and 2 would not fit I was lucky the last one I had did fit. The doors needed tuning but fit nice now. Fenders and hood same tuning. Same on the Hollywood. Gapping was a pain in the ass.
I was done my 51 in a tenth of the time.0 -
Recently involved with trying to get a '50 Pacemaker hood to open without catching either the vent or the bulkhead and removing paint. Only way we can actually do this is to have the front overlapping about half an inch, which doesn't look good. Maybe we have to loosen the front bolts holding the whole front assembly together and try and move things around that way. We have already knocked a lot of paint off! Precision it is definitely not!0
Hi All,
Other than obvious body part fatigue - look for cracks and loose spot welds at the hinge mounting points, hood and cowl...or outright body damage...the culprit is the helper spring thats part of the rear hinge assembly.
Not the mid-hood braces with the round winding spring..these hinges are on rear of the hood and bolted to the cowl.
On my 49 although you can unbolt the hood..the helper spring is behind the fender. And pretty much requires removing the fender.
A lot of times these are broken or very weak with age and rust eating away at them.
What that rear helper spring does is actaully lift the rear of the hood up before it moves back.
Without the "up" action in the rear..you'll be dragging sheet metal on the cowl and or cowl vent edges.
I don't know of a source for those springs..I went with modern hinge assist shocks.
Dan0 -
I dont know if it will help but I have scrapped a lot of Stepdowns. And have noticed if I support them at the firewall with jackstands as I take it apart. The weight of the engine will bend the frame as sheet metal is removed.
This is not obvious until you go to pick the motor .I could see where if you were not carefull you could bend things to the extent that Geoff was was talking about ,
Roger0 -
When discussing the hood catching the cowl vent and/or the edge of the cowl,you must look at the condition of the hood hinges. If the rivets-[pivot points]-are worn,it allows it to move around in excess and cause problems adjusting it. Other body parts??? as mentioned here,later on,quality ?,writing was on the wall.0
I’ve had a lot of old-time, knowledge Hudson guys do the slow, low chuckle when talking about panel fitting on a Hudson, in particular on a step-down. After the chuckle, there was always some comment like, “Yep! Sounds like a Hudson.”
IMO, Step-downs (all I can attest to) have some of the worst fitting and ill-gapped sheet metal of any production car I’ve seen. That said, there’s a lot of variables that go into that statement that one has to take into account.
Firstly, remember that blocking out panels, setting the gaps to exactly 1/8” (or whatever), is a modern, usually high end shop technique that has been taken to the extreme, particularly on the over-restored show and trailer queens. Originally, these cars didn’t have ANY of that fussiness done to them. From a production standpoint, there simply wasn’t the time or the money to be wasting on the line. The ONLY production car I know of that had that kind of lavishness given was a RR. No American mfg. that I am a aware of, went to such extremes. What was close? I don’t know, I wasn’t there, but I’m reasonably sure that if it was ¼” max. gap, and within ¼” laterally, it was “good enough”. Sounds pretty far out there, though, doesn’t it?
Secondly, one must remember that immediately after a flat piece of steel is stamped into a different shape, i.e., a door, fender, quarter, decklid, whatever, it is under stress. The stress never goes away, a week later, or decades later. What happens is that body panel continually fights to get back to it’s original shape, which means that it changes as time goes on, from where in space it once was. The more time that passes, the more it has changed. Some will change more than others, due to the nature of the metal to begin with, the atmospheric and geographic location of the part, how much wear and tear it’s been exposed to, etc. An automobile that has seen limited use, has never been “adjusted”, taken apart, or molested in any way, will have panels that “fit” differently than the day they did when it came off of the line. It is absolutely inevitable and unavoidable.
OEM quality is an amazing and necessary technology that the automobile companies have been employing for decades. In it’s most basic application, it means that you can take a door off of the rack and put it on any body that it was designed for and it should fit with minor adjustments. Most of the time, that’s exactly how the process works. It works better on replacing water pumps that it does a fender, mind you—too many variables. Which brings me to, Thirdly, a set of dies that were manufactured to make a quarter panel for a 2DR Step-Down, let’s say, might be good for 10,000 stampings. The reason they have a “limit”, is the metal on the dies starts to break down, change shape, and “wear off (or out)”. Eventually, whatever tolerances the engineers set for the discrepancy between the first stamping and the 10,000th stamping have reached maximum allowances. I don’t know for certain, but my guess is the difference is not in the thousands-of-an-inch, but more like ¼-3/8” difference. Fender #1 of a new set of dies is not going to be the same as Fender #9567. There is simply no possible way.
So, that’s only three factors that go into the relationship between two adjoining body panels on a 60+ year old car. There are others, but those cover my objective. Question is, what can you do? My opinion is based only on my experience and success ratio, nothing more. Because the old tin has “slow-changed” over time, you have to shock it back into shape. If you have a door that is twisted beyond what can be adjusted out with the factory adjustability limits, the solution to remove the twist not to do the elephant leaning on the tree till it bends technique, but, rather to instantaneously “shock” the door back to where you want it to be. Moving it slowly will only allow it to get back where it “wants” to be in a short amount of time, sometimes even in a few days.
If you are in the middle of bodywork, go ahead and lead some of the gaps in, or shave some off of a high spot, whatever it takes. Do some panel fitting, but don’t go over the edge. You’ll drive yourself crazy, the car was never “perfect” to begin with. My advice is to set some parameters that you will be happy with and stick to it. Don’t over-restore, it’s metal, not poured plastic.0 -
"Other body parts??? as mentioned here,later on,quality ?,writing was on the wall. "
Agreed. Goes along with cars made on Monday, or sometimes Friday . . . or during a strike.0 -
A lot of useful information, thanks all. After fighting with the hood, shiming the hinge, wrestling with right front fender, and installing the hood latch and rubber guides, everything actually looks pretty good. The hood clears the vent without a big gap, and the gaps on each side are now pretty good. The only remaining issue is the driver's door, which has about a 1/2" space along the leading upper bend. May weld in a 1/4" strip and finish.0
Same here with a little effort I was able to get the panel fit pretty darn close. I only attempt fit and finish like it came off the line. I agree with Russell I see no point putting in Herculean efforts to laser match the gaps. I have gap gauges I get it close and I am happy.
Talking about over restoring I watched a show the other day where a guy paid 135K to have a 61 Tbird restored. It looked like the day it rolled off the factory floor but 135K he will never get that money back out. A friend of mine tried to sell me a red 61 TBird that was original looked like the day it rolled off line he wanted 30K. It was a beautiful car low miles it had under 50k original miles had be garaged its whole life and for last 25 years only driven in summer maybe 100 miles per year. Whole point is you can still find nice cars without spending crazy money.
I just bought paint supplies for my cars and boy if you had to pay a painter to do your car you would be screwed. I talked to a friend who runs a body shop he told me if you do all the work and he just shoots it will still cost 5k minimum if you want a nice job. So restoring cars is very expensive. I do all my own work except interior and even I am having a hard time justifying spending and working a restoration when I can pick and choose cars for fraction of cost. I am in the group that works on cars for distraction but any new cars I want I will buy.
Sorry for starting out on topic and running off the rails :woohoo:0 -
dougson wrote:A lot of useful information, thanks all. After fighting with the hood, shiming the hinge, wrestling with right front fender, and installing the hood latch and rubber guides, everything actually looks pretty good. The hood clears the vent without a big gap, and the gaps on each side are now pretty good. The only remaining issue is the driver's door, which has about a 1/2" space along the leading upper bend. May weld in a 1/4" strip and finish.
Sounds like a good plan. I had to lead in one side of the cowl on the 'vert. My gap wasn't quite as big as yours, but I had those kinds of gaps elsewhere.0
- 104 Hudson 1916 - 1929
- 172 The Flathead Forum
- 599 Vehicles
