Stepdown Overdrive switch plug
ernie28
ernie28 Expert Adviser
Can someone please advise where I might be able to get a replacement plug for the overdrive switch on my '50 Pacemaker. It is bakerlite with four terminals (maybe the same as for other years etc).
Thanks all in advance
Alistair
NZ
  • Richard E.
    Richard E. Senior Contributor
    Contact Jason at Vintage Coach (Bill Albright's grandson.)
  • ernie28
    Thanks Richard, I am getting other stuff from him also so will add to the list.
    Alistair Alistair, if you have the early 50 OD for your Pacemaker you should have the 4 pin model with the pin arrangement looking like an old radio tube. The later OD units used the Essex plug that looked very close to a headlight socket but had 4 prongs instead of 3. Check and see which you have.
    NZ
  • ernie28
    NZ
    Thanks Hudzilla, The plug has four wires and recieves four flat pins from the switch behind the accelerator pedal. It is made of a ceramic type material (not barerlite as first mentioned). Make sense? I can post a photo when I return home later in the week if need be.
  • You have the Essex type plug. They are a bit more plentiful than the previous type of OD plug which uses a radio tube type base.
