Rocker Panel exchange
I have posted this numerous timres but it never shows up.. Where the devil is it going?
I have a N.O.S. rocker for the right hand side of a 51-53 Hornet or Commodore I will swap for a right side 48-49 Commodore. Stu doesn't have one. Any one want to swap?
Did you check the other two sources I sent you?0
Are those the same as 51 Super (flat pieces of stainless)?0
Are what the same? . The PN of the panel I have is 225736..the one I need is 211346 which . fit the 48-49-50 Commodore. The 51 Supers use number 225734 so are different...all numbrers I listed are right hand four door numbers.0
- 115 Hudson 1916 - 1929
