oil types for 28 super six.trans, motor etc.
Unknown
edited May 2012 in HUDSON
acquired total restore but motor turns free.still had oil! want to test soon with gas can after tune up and temp.wiring but the carb has 2 feeds from the firewall can,top of carb. and bottom.the top is capped right now can i just feed gas into the bottom ?thanks
  • also all oil types and weights would be greately appreciated.
  • ESSX28-1
    ESSX28-1 Senior Contributor
    I use 15w40 oil in my 28 Essex Super 6 engine & 140 grade in gearbox & differential. Be careful NOT to use oil with EP additive in the gearbox - they conflict with the bronze bushes.
    Pull & carefully clean out sump before starting engine
  • thanks for the oil weight. any info. for temporarily feeding carb. ? /
  • charles4d
    charles4d Expert Adviser
    Hi try this web sight Penngrade1.com/zinc this should answer any questions on oil
    Chip / Charles4d
  • Geoff
    Geoff Senior Contributor
    Are we talking Hudson or Essex Super Six?
  • Jon B
    Jon B Administrator
    edited May 2012
    giardina: heed whatever Geoff says! His daily driver is a '28 Essex and he is the ''go-to'' guy in New Zealand for Essex (and other earlier Hudson) repair.
  • 1928 essex supersix coach,thanks for comments. paul g.
  • also have need of horn ring/button and levers what was left of the old one was a plastic ringinside the steering wheel.or a good steering wheel would be great.
  • Geoff
    The main thing is to steer clear of heavy monograde oil in the engine. 15W-40 as Dave says, is fine. Penrite gear lubricant, 140 for the diff is fine, or modern 90W-140 for both transmission or rear end is also okay. Modern oils do not affect bronze bushings, just the old types with sulphur in them. I cant' help with horn ring etc, as our r.h.d. cars are different. Use oil in the king pins, not grease, as there is no fitting at the bottom and grease will not get down to the bottom of the pin. Good luck,
    Geoff
