rocker panels for jet
[Deleted User]
edited May 2012 in HUDSON
hey 53jetman; I need rocker panels for my 54 jet, any Ideas where to get them. Tried 2c2fabrication, and rock auto.
they both have them,but not for a jet.
Gene
  • Geoff
    Geoff Senior Contributor
    It's not too big a job for a body shop to fabricate new ones. Unlike Step-downs, these are not a bolt-on item.
  • thanks Geoff, that was my next step, I had to replace the outside frame rails, I used 2x4x
    14gauge rectange tube. what gauge do you think the rockershould be? thank you
    Gene
  • 53jetman
    53jetman Senior Contributor
    I had 16g galvanized replacement rockers fabricated back in 1967 for my 1953 Super Jet. What you have to watch is that there is a slite horizontal bow to the rockers from front to rear, but it can easily be handled as you tack the new panel in place.
    Jerry (53jetman)
  • 53 jetman; I droped the plans for new 16 gauge rocker panel, at the sheet metal shop today.
    tell me some more about the bow. I did not see it when I removed them. Thanks Gene
  • 53jetman
    That's what I meant by a SLITE horizontal bow. It will become apparent when you start to attach the new panels. I started about in the middle of the front door opening on my four door and worked both ways alternately until I had it tack welded to the inner frame rails top and bottom. Once tacked, I then went back and did the Finnish work.
    Jerry
  • thanks: I will be putting them on over the week end. I shoiuld pick them up tomorrow.
    Gene
