49 Door Post Wiring Question
The wiring was hacked on my car when I took it apart, and the diagram I have versus the directions that YNZ supplies are different, so here I am. My question is as follows for a 49 Comm Conv. (would be same for coupe):
On the PASS door post SWITCH, how many wires are coming off of it? I only have one at the moment, but the factgory diagram shows one going off the other post and going to the dome light. Can someone please confirm what is correct? Either I am missing a wire from my harness or the directions are wrong, or I am just hallucinating from looking at wires for two days.
Thanks
Thanks
That is correct power came from under the dash went up through the coupe top drop down the pass door pillar to the switch, went back up to the rear int lights0
