1931 Essex Cylinder Head?
I'm trying to find the correct torque spec for the cylinder head bolts. I've looked in the Hudson 8 Manual and did not see anything other than tighten a little at a time and then after the engine is warm go back and tighten them again. I have yet to find a shop manual for the 31 Essex. A little help? Thanks.
Geoff Clark or David Young or Will Moon should be able to help you
Mike0 -
For a '28, 40lb is what has been recomended to me but as mentioned by Mike, Geoff will be able to clarify.
Yes, 40 lbs, and tighten from the centre outwards radially in sequence. Re-tighten twice again when engine has been thoroughly warmed up.0
Where would I look to find this information? I really need a shop manual. Thanks everyone for your response!0
Sorry, the inside of my head is not open to the general public. Shop manuals were not printed for the '31 models specifically. There is a mechanical procedures guide for the '30-'33 Hudson 8, but this does not include torque settings. General common sense is the most apt thing, use a small ring spanner, rather than huge socket wrench handle, then you are not in danger of screwing the top of the stud off. Personally I don't use torque wrenches, they rob you of the feel of how tight things are.
Geoff0 -
My old book says 35#, but I torque to 40#, then warm up and re-torque, run and re-torque, then check again after you've driven it for a while. And on my final snug up, I have to confess I do it with a long box end wrench, not a torque wrench. The torque wrench lets me bring them all up evenly, but nothing beats 50 years of "feel". I can tell when it's stretch. As a long dead grease monkey friend of mine once said to me, "Ain't nothin' like drillin' out a few to teach ya ta lighten up......."0
And I almost forgot. If you don't bleed on your car at least once, it won't run worth a flip0
Ok! Thanks for all the information. Now if the headgasket makes it in the mail I will be set. :-?0
