12 Volt fuel pump
1954Hudson
I have 350 Chev engine,i do not have room for machinal fuel pump.What is the best quailty elect pump to use,that will last when useing it all the time. Thanks Ron
I have a carter rotary vane pump on my Jimmy. Works great. I believe they don't need a return either (mine runs through the old pump with a return).
http://m.summitracing.com/parts/crt-p40700 -
i used a Holley push pump as I set it up by the tank, make sure you use a adjustable pressure regulator so you can adjust pressure to suit your carb
mike0
- 97 Essex Super 6
