modern thermostat install
I can't seem to find the discussion and picture of the modern replacement of the old thermostat on a 54 hornet 308. As I recall you buy a cup freeze plug and drill a 1/8 in hole in the middle and buy a modern thermostat to improve the water cooling. Would someone please tell me what size plug to get and the thermostat to buy (probably get a fail safe). Thank you for your suggestions.
11/4 soft plug. Seventies era AMC thermostat. Take your housing with to da parts store.
Kim0 -
160 degree CarQuest thermostat #302360
Get Walt's by pass kit. I'm in the WTN. Walt0
I have Walt's bypass kit on my 52 Hornet and it works great. Never gets close to running to hot. Lee O'Dell0
My Hornet's problem was not warming up very readily and running very cool coming down a long hill ... tough to get good heat from the heater. Walt's kit solved that problem, too.0
whats Walts? I need to get this bypass kit mines over heating a bit. thanks
I'm Walts Garage, I write tech items for the WTN and also make a few parts for Hudson cars. Contact me at aaawaltmordenti@aol.com Drop the 3 a's as that is there to fool the computers that pick up address and send junk and spam. Walt.0
- 114 Hudson 1916 - 1929
