Gas Tank Sending Unit - 1949 Hudson Commodore
Talk to Paul Schuster ,he has had the originals reproduced by the original maker. He is on the forum as PAULLARGETYPE,
Roger0 -
So, do these fit Hudsons earlier than StepDowns?0
YES THEY FIT ALL THE WAY DOWN TO LATE 34 OR 35 DEPENDING ON WHAT TANK YOU HAVE IN YOUR CAR MY SENDING UNITS WILL WORK ON 6 OR 12 VOLT AND ARE THE CORRECT OHMS THE FORD ONE DO NOT HAVE THE RANGE OURS DOES 53 54 YOU NEED TO DO A FEW THINGS TO MAKE THEM WORK BUT NOTHING BIG OR COSTLY IF YOU NEED ONE LET ME KNOW BY THE WAY DR. DOUG GETS HIS FROM ME0
I just ordered mine from Paul. Sounds like it's just the ticket!0
PAULARGETYPE - how much are the sending units and how does one get in touch with you for ordering?0
I think the Ford unit you have will work, but you need to bend the wire that the float is connected to. The sending unit will only go on one way.
Paul Schuster is listed in the White Triangle News on page 38 (of the current May/June issue), under Member Products and Services. The White Triangle News is the official publication of the Hudson Essex Terraplane Club.
Paul Schuster can be contacted at HEThudson1957@aol.com (drop the HET)
Want to become a member of the Hudson Essex Terraplane CLub?
Contact me at HETForkner@aol.com (drop the HET)
John Forkner
- 114 Hudson 1916 - 1929
