308 head removal
If you pivot the head you also bent some valve heads. Head has to come straight up so as not to bend any valves. That's the reason to use line up dowels, to remove and to install. Walt.0
One way is, get yourself some sharp drill bits and start drilling. It won't take that long,just try to stay centered and straight in the bolt. You only need to drill the depth of the cylinder head. Once you have drilled down ,it will finally relieve itself. And as Walt suggest,don't twist it back and forth,will only cause more work. Also,be careful not to scare the deck of the block,this will cause cylinder head gasket problems and concerns upon re-assembly. Hope this helps,CG
- 104 Hudson 1916 - 1929
- 172 The Flathead Forum
- 599 Vehicles
