54 hornet 4 door passenger side window trim
replacing all the glass and can not continue until I repair or replace these stainless trim parts. Any one have these? before trying to have them repaired,if even possible, trying to find replacements.
Replacing the oil pump gear and noted that the pin had wallowed out the hole in the gear allowing the gear to move about 10 to 15 o on shaft. Am thinking this might be the reason that my distributor timing is all over the place????? After running car in gear ,replacing into neutral engine races up to about 1,200 RPM??? Rodney
Rodney I have them.0
Great,My cell# is512-964 0361...0
