Carpeting in my 54 Coupe
What would be the best way to install the carpeting under the clutch and brake pedals? I have tried and then after a while, the carpet then slides down into a folded position. Not only is it unslightly but it is a pain to try and reposition the carpet only to have it slide down again. Any help would be greatly appreciated.
Richs.
Richs.
Self-adhesive Velcro dots or strips?0
Along this same line, I will be carpeting a 54 sedan and need to find out if there is any vender out there than makes form fitting sets,or will I have to make a custom set ????. Is there any one out there that can do this?0
Richards, The floor covering of my Hornet Special was a rubber mat and fastened to the lower firewall with sheet metal screws in 4 or 5 places. I believe your original carpet was held up there in the same manner and the holes should still be there.
Bruce
W/NY Chapter0 -
Isn't the front carpeting held in with snaps in '54? I thought I remembered seeing something like that in '54. Little chrome, button head type snaps that you would push on or pull off.0
Hi Bent,
Maybe on the 54 Hornet but on my Special which had 69,000 miles and the wet/damp stinky jute under the old stiff rubber mat, they were screws!
Bruce
WNY/Ontario Chapter0 -
Thanks guys, I will investigate and see if the holes are there. Richs.0
- 114 Hudson 1916 - 1929
