Carpeting in my 54 Coupe
[Deleted User]
edited June 2012 in HUDSON
What would be the best way to install the carpeting under the clutch and brake pedals? I have tried and then after a while, the carpet then slides down into a folded position. Not only is it unslightly but it is a pain to try and reposition the carpet only to have it slide down again. Any help would be greatly appreciated.
Richs.
  • ESSX28-1
    ESSX28-1 Senior Contributor
    edited June 2012
    Self-adhesive Velcro dots or strips?
  • Along this same line, I will be carpeting a 54 sedan and need to find out if there is any vender out there than makes form fitting sets,or will I have to make a custom set ????. Is there any one out there that can do this?
  • brumac
    brumac Expert Adviser
    Richards, The floor covering of my Hornet Special was a rubber mat and fastened to the lower firewall with sheet metal screws in 4 or 5 places. I believe your original carpet was held up there in the same manner and the holes should still be there.
    Bruce
    W/NY Chapter
  • bent metal
    bent metal Senior Contributor
    Isn't the front carpeting held in with snaps in '54? I thought I remembered seeing something like that in '54. Little chrome, button head type snaps that you would push on or pull off.
  • brumac
    Hi Bent,
    Maybe on the 54 Hornet but on my Special which had 69,000 miles and the wet/damp stinky jute under the old stiff rubber mat, they were screws!
    Bruce
    WNY/Ontario Chapter
  • Thanks guys, I will investigate and see if the holes are there. Richs.
