Info on Toledo Steel Pistons wanted
Dave, my Toledo catalog dated 1951 has no reference to that piston number - there is a gap in the sequence of numbers so I believe an earlier catalog may help. My catalog does list two categories of pistons: "Alloy or Cast". Do you know the std bore they could fit - are they .060 over ? May be able to ID from that - in another brand catalog - that I may have.
Gert Kristiansen0 -
They were sold to me as "semi finished' for the 29 Essex engine (std bore = 2.75") but the bottom (4th) ring (below the gudgeon pin)is not usual for that engine.0
