turn signal wiring for 53 super wasp
i have a 53 superwasp and im drawing up the wiring diagram for my car for my rewire. im converting to 12v and other goodies but my shop diagrams dont have the wiring for the turn signal. when i bought the car it came with working turn signals that look stock. does anybody have a diagram for the turn signal?
This is true as I just purchased the '53 - '54 Hudson shop supplement from the club store and noticed the "Directional Indicator Installation" under section 17 (Accessories) of the supplement. This should provide all the information you need for rewiring the turn signal. Good luck!0
thanks guys you helped a lot ill definatly look into that. ill post my final diagram when im done drafting it out. adding a fuse block, dual headlight relay, msd ignition, e cooling fan relay with tstat, adding in the rheostat from a hornet, also adding rear dome lights from a hornet, etc0
Also try Rhode Island Wiring. They sent me an excellent turn signal diagram for my 54 Hornet. And the price was right., free.
Doug0
