Another - What is this, is it Hudson?
That particular part is used the rear fender skirts on stepdowns. It helps locate and line up the fender skirt flange and orient it properly on the rear wheel opening. There are usually a couple per side. Not the end of the world if you don't use them.0
Thanks for that. The boxes of misc bits are coming to an end.0
