Brake parts needed for 36 Terraplane
junkcarfann
Hi guys...I need a master cylinder and brake cylinders for a 1936 Terraplane. Any suggestions of vendors? Thanks.
Someone will step in here shortly and give you the magic interchange info soon, I'll bet. Just be aware that it is possible to sleeve your old ones (there are several companies doing this, White Post Restorations is one) so that they'll never corrode again. And when you put the thing back together again, you might want to consider silicone brake fluid. I've been running silicone in my 1937 for the past 15-20 years with no adverse effects.0
Brake parts for 1936 Hudsons are as follows.
Master Cylinder: NAPA M4360, Raybestos MC4360, Wagner MC1476
Wheel Cylinder - Left: NAPA 7564, Raybestos WC7564, Wagner WC9337
Wheel Cylinder - Right: NAPA 7563, Raybestos WC7563, Wagner WC9336
The application of the above part numbers is 1936 to 1947 Hudsons and Terraplanes.
Thank you!0
