37 carb-intake related questions
Kdancy
Kdancy Senior Contributor
edited June 2012 in HUDSON
I assume the copper tube is for heat riser? Not one on this vehicle.
What does the tube on bottom right of intake manifold go to?
  • Huddy42
    Huddy42 Senior Contributor
    I think you will find they are to do with vacuum clutch set up.
  • Kdancy
    If that's the case, I can just block them off.
  • Geoff
    Geoff Senior Contributor
    The one on the left is for the windscreen wiper.
  • Geoff
