i'm looking for hyd lifters for a 56 308
PAULARGETYPE
i'm looking for hyd lifters for a 56 308 do i remember some one saying that a mopar lifter would ??
I have a set that came out of the spare 308 that came with my 49. Block,crank and pistons
were all new never run standard pieces but I wouldn't swear that on the valvetrain...
Make sure you have the correct cam to go with them. Walt.0
I know Mopar 'mechanical' lifters will work with custom length valves, but not sure about Hyd Lifters.0
For hydraulic lifters, you must remember each inner part is mated at the factory with the outer part. You can not change them, factory orders. They are machined to fit each. Walt.0
1. The image issue has been fixed by the look of it.
2. To delete a post, all you need do is click the word Delete on the post of yours that you want to delete.
On those two counts, the system is very much up to par.0 -
My mistake, I had to join as a regular member to confirm this. You can only edit your own entries, not delete them. Moderators only have the option to delete entries. Pretty standard forum fare.0
There is a set of 24 Cadillac lifters on the AACA forum,buy and sell section.
$20.00 each if you buy all,$24.00 each seperate.1941-47 Cad?
Roy0 -
THANK YOU ALL FOR THE GREAT INFO0
- 114 Hudson 1916 - 1929
