CARB QUESTION
I HAVE A 1954 HUDSON WASP...262 ENGINE WITH A CARTER 2115S CARB
I HAD THE CARB REBUILT AND IT IS RUNNING FINE WITH THE EXCEPTION OF ONE SMALL PROBLEM
I AM GETTING A SLIGHT HESITATION WHEN I ACCELERATE AND IT APPEARS THAT THERE IS NO GAS
BEING SPRAYED FROM THE PUMP JETS. WHAT IS CAUSING THIS AND HOW WOULD I TROUBLE SHOOT
THIS PROBLEM..
THANKS,
TOM
THIS PROBLEM..
THANKS,
TOM
HI, TOM-WA- THIS IS HUDNUT52.YOU SIDE YOU HAD CARB REBUILT I WOULD CHECK THE SCREEN UNDER THE ACCELERATER PUMP AND THERE IS A CHECK BALL UNDER SCREEN.0
If you rebuilt the carb, most kits have the short accelerator pump. Did you compare the length of the old pump with the new one? Most are 1/4 inch shorter. Walt.0
