Vacuum Wiper Model Number
Don't know about the model - but the Hudson part number was 202151, page 311. According to the 1948-1954 Master Parts Catalog it was common only to 1950 models.
Manual may be found at: http://hetclub.org/burr/lithomepage.htm - click on 1948-1954 Manuals.
Alex Burr
Memphis, TN0 -
Thanks Alex, hopefully someone may be able to advise the Trico number also.0
Thanks for the boot in the butt - when you mentioned Trico number I remembered I had the 1948-1954 Trico bulletins in the online library - http://hetclub.org/burr/lithomepage.htm - click on 1948-1954 Bulletins.
The Trico number for the motor is CSM-4-3, for Sedan, Brougham and Coupe all models. I see that I got the Hudson part number wrong in my previous post. Should be 220151.
Alex Burr
Memphis, TN0 -
Thanks Alex - just what I was looking for0
Ernie i have a Trico here that came with my 31, would need a rebuild but you can have it if its any use to you
Mike0 -
Thanks Mike
I understand they are quite different from those used in the '50s but I will keep your offer in mind.0
