Electrical problems 54 Hornet
Where does the power come from that goes to the neutral safety switch for hydra matic trans.
I have power to coil. no power to solinoid when the key is turned to start position. I have wiring diagram for car gut does not show wiring to neutral safety switch. Please help. Ray
Ray, you have two leads to that switch. One is from the small terminal on the solenoid and the other is to the ignition switch. Hope this helps.
Doug0 -
Thanks Doug, Ray0
- 114 Hudson 1916 - 1929
