Hornet Distributor problem
I was working on replacing the coil wires and lead wire to the points on my '54 Hornet tonight, and noticed the bakelite insulation had split apart where the wire passes thru the distributor.It appears to be a double nutted stud that secures the bakelite? Is there a fix for this problem? Or does someone have a ready to run distributor for sale~ Thanks!
Super glue!0
I have spares-send me your address
Randy Maas0 -
Randy, I pm'd you my address, I hope you got it and sent a spare out! Thanks Again! Scott0
- 114 Hudson 1916 - 1929
