What does Unit Engineering mean?
The 1932 models introduced "unit-construction" engineering, which combined the all steel body and floor pan together as a single unit. The "unit body" was attached to an X-member frame with twenty-two attachment points. Engineering and Safety!
This (above) practice was one of the reasons the thirties Hudsons were lighter than they looked. Mutually reinforcing frame and body meant each could be made a bit lighter.0
Thank you both for your insight. Big help.0
No-one quite believes me when I tell them that my '36 Terraplane is a fair bit lighter than my Subaru Impreza which looks very much smaller!0 -
Another thing that amazes folks is that from mid-thirties until the stepdowns, Hudsons typically had better than 50-50 weight distribution. My '47 C8 sedan has 150 pounds more on the rear axle than on the front. What other American car of the time matched that?0
Indeed. I put my Terraplane over a weighbridge one axle at a time to work out the total car weight and front and rear axle weight, and it was also a little heavier in the rear than the front.0
Park, according to the weight sheets I have in the General Information Handbook your Commodore 8 Sedan was listed with a shipping weight of 3330, license weight of 3305 and a total weight of 3430, split at 1730 front, 1700 rear.
Looking thru these sheets the balance is incredible. Most front and rear weights are within 50 or 60 pounds front to rear, or less.
Alex Burr
Memphis, TN0 -
Alex, I got that data from your info sheets, but must have misread something. Anyway, I'll take a 30 lb. difference as 50-50. I recall being astounded back in '55 when I stuffed an eight in a '35 Terraplane coach and it still had better than 50-50 distribution. No darn wonder it was hard to squeak the tires on my stock '37T !0
Thank you everyone! Thanks for giving me some great information.
Todd0 -
It always amazes me that a lot of Hudson's weigh in at less than modern cars. I don't think the industry cares about weight savings much now. They should...we would probably get better gas mileage. Even with plastics and and aluminum block engines they weigh more which I don't quite understand how that is.0
New car extra weight comes from a ton of insulation, so we can wisper to each other, A/C, cruise control, electric heated bucket seats, TV's and pretty much all the conviences of home except the kitchen sink. Unless it's a minni camper. LOL
Lee O'Dell0
- 114 Hudson 1916 - 1929
