shipping a step down door
Chris Smith
I have an opportunity to buy a step down coupe door I need, but I have to get it from the east to the west coast. I need suggestions on how to get it shipped at a reasonable rate. Its a door shell so it should not weigh more than maybe 60 or 70 pounds. If I have to pay more than a hundred or so dollars shipping it wont be worth it.
try greyhound bus co. not a joke cant hurt0
Chris-
I have not tried it, but charles4d is right, Go Greyhound! It is posted here on the forum quite a lot as a fairly inexpensive to ship those big items that UPS would want an arm and leg for.0 -
Yes , thats what i use . Go to thier web site and go to Greyhound Frieght and you can get a quote. Usualy about $45-$70 for the stuf I have sent (fenders and doors). Needs to be packed in bubble wrap or something so there are no sharp edges.
Roger0 -
Thanks for the tip guys looks like just under a hundred bucks on Greyhound plus whatever wrapping charges will be as the elderly person who is selling it does not want to mess with packing. I will be lucky if he agrees to take it to the bus depot after i offer to pay a mom and pop mail it all shop to bubble wrap it.0
The guy who has the door also offered me a complete power brake assembly with the swing pedal and vacuum canister for $300 Knowing that I will likely have to spend another $400 to have the treadle vac rebuilt, is it a fair price and worthwhile addition?0
Depends on how "complete" it is there is linckage and fittings ang vacume tank etc. that are particular to the 54 pawer brake cars.
Roger0 -
there are three linkage or support rods,fluid hose?, vauum tank, master/booster, swing pedal assembly, a valve of some sort, a spring with a small bracket on one end.0
AAhh good -it does sound like prety much the whole works then,
Roger0 -
There's always that fellow Jim, what's his name hauls cars AND parts all over the country. Somebody will come up with his name.
Alex Burr
Memphis, TN0 -
Jim Guinn is the Hudson hauling guy. Not to add more confusion to your situation, but have talked to Lance Walker to see if he has the parts you need? He has shipped me stuff on Greyhound (well wrapped too) and didn't charge an arm and a leg. Might be worth a call before you pull the trigger on the other guy. $300 seems a little high on the power brake setup, but maybe not.....I have never purchased one......
Good luck
Don Crane0 -
They are just very hard to come by , in particular a complete set up like that. You do see the vacume tank or the treddle-vac but never the whole works as a kit,
Roger0 -
I'm sorry, but are y'all talking about a complete power brake set-up for a '54? 'Cause I've seen those go for $1500, not counting the cost of installation.0
Russell
I have seen power steering setups for big money, but I think power brakes are a little more common......0 -
Don-
My mistake! You are correct! I was thinking of the power steering . . .0 -
The power brake set up isn't worth your time, money or trouble. If for no other reason that with power brakes, you lose the famous mechanical back up brake system0
- 104 Hudson 1916 - 1929
- 172 The Flathead Forum
- 599 Vehicles
