Clutch Question
TOM-WA-
TOM-WA- Senior Contributor
edited September 2012 in HUDSON
I am unable to shift my 3 speed trany from neutral into any gears.....i went to drain the clutch fluid to check
its condition and found that none was there....
If I refill the clutch fluid with 6oz of new fluid and run the engine for awhile engaging the clutch pedal in and out
do you think that will remedy the no shifting problem?
Any thoughts or suggestions are appreciated.
TOM-WA-
  • SuperDave
    SuperDave Senior Contributor
    Sounds to me like the disc has stuck to the flywheel. I would replace the fluid and prop the clutch pedal down over night and see what happens.
  • Quite often if its not stuck bad you can put in first gear ,hold clutch in ,and "Bump " starter.
    This may pop it loose , I do agree you need to fill with fresh oil and prop clutch overnight first,
    Roger
