311040 cam
Was just wondering if this cam gives more power at low RPM's or high RPM's or exactly what does it do.I havd a 311040 in the 54 Hornet when I bought it . The car had a single 2 barrel carb and regular size valves. but 1 of the lobes was flat. I found a nother 311040 and big hudson valves and also installed a Randy Maas timming chain. It fit like a glove thanks Randy. Hudsonly Ray
You can get some more input to be sure but it may be a good idea to have someone measure the lobes. I understand Hudson re ground some of them in the 308 to get higher lift,
Roger0 -
'most any performance cam produces its power benefits at somewhat higher rpm's while reducing slightly at the low end. The big difference is just where in the higher-up range that benefit occurs.0
- 104 Hudson 1916 - 1929
- 172 The Flathead Forum
- 599 Vehicles
