O/D Wiring Help @ Relay, please
[Deleted User]
edited September 2012 in HUDSON
I lost the pictures I took of the O/D Relay wiring. So now I need help in figuring out which wire goes to which pin on the
Relay. I am having to go with push-on spade terminals since I can't locate a replacement plug end.
The Service Manual I have shows a six wire connector but I only have a 4 wire.
I do know that the single wire from the Governor goes to the angled spade on the relay. And the spades are numbered 1, 2, 3, 4 on the Relay.
  • MikeWA
    MikeWA Senior Contributor
    Here's a diagram, if that helps.image
  • [Deleted User]
    MikeWA,
    THANK YOU!!! This is NOT is the Service Manual I purchased. What manual is this from?
    I can actually follow/trace the wires in the engine bay and figure it out now.
    I have already found I had it wrong to start with. But the wires were all frayed cloth and I think they were shorting out before I took ownership.
