Inner & Outer Tie Rod Ends
[Deleted User]
edited September 2012 in HUDSON
Are there any less expensive "swap" Inner & Outer Tie Rods ends other than the $100 per end parts ($400 total) at one of On-line "Older Car" auto parts stores.
  • Pacemaker - Try to find MOOG - ES 416 L & R. You should get them at any good parts store for about $25. Same as '50s Ford pickup. Norm
  • Great!!! Is that price per inner and outer end so total would be $100ish?
  • bob ward
    bob ward Senior Contributor
    As Norm says, Fords of the era. My notes say 49-51 Ford cars, small Ford trucks 35-52, Mercury 39-48 and 49-52 Pilot (a UK Ford).
    Apart from Ford and stepdowns no one else seems to have used that tie rod end.
  • Ducor Kid
    Ducor Kid Expert Adviser
    Rock Auto has them $22.79 plus shipping.
    Larry
  • Uncle Josh
    Uncle Josh Senior Contributor
    the inner on one side is the same PN as the outer on the other side
  • Ducor Kid,
    What part number did you use to search or did you search by Year, Make, Model?
    Uncle Josh,
    Thank you for helping me understand. I wanted to make sure that Left & Right did need special parts threaded in the opposite direction.
  • bartibog1
    bartibog1 Expert Adviser
    you can get them from dennis carpenter ford reproductions 16.00 ea just goggle them and enter 48 to 56 ford truck + shipping
    steve
  • Ducor Kid
    I looked for a 1950 Ford F1.
  • Thank you all for the help. This is one of my winter projects.
