Help with part number
Trevor J
Trevor J Expert Adviser
edited September 2012 in HUDSON
Can anyone assist. I have a NOS brake drum that came with a lot of Hudson Parts. It has the part no 100316.
If anyone can heplp that would be appreciated.
Thanks Trevor NZ
  • RL Chilton
    Trevor-
    That part # must be pre- step-down. I don't Parts catalog for earlier models.
  • hudsontech
    hudsontech Senior Contributor
    It is pre-stepdown - it's for 1932 Terra K coach and sedan, 1933 Terra. K, KT coach and sedan.
    The big problem is, according to the 1927-1939 Numerical Parts Price book it's a right hand rear roof rear trim rail!!!!!!
    Check out the book - it's in the online lubrary, under 1920-1929 Manuals file. You can type in a search to quickly find it.
    Alex Burr
    Memphis, TN
  • Trevor J
    Hi Alex Thanks for going to the trouble. That Is the number stamped in raised letters on the drum also has a ticket wired to it with the same number. Maybe its not Hudson.
    Regards Trevor
  • hudsontech
    The number is Hudson, tho it's a remote possibility that it's a part number for some other make. But that would be a stretch. The number stamped in raised letters may be a Bendix (I think they did the brake systems for Hudson) number and somebody took it for a Hudson number and attached a tag with that number.
    And no trouble to look it up - as I say the parts book is in the online library and most of the material in the manuals section is searchable. Interesting that the number is not in the 1927-1950 Numerical Parts Price book; it is, however, in the 1933 Terraplane body parts list as the above trim rail part.
    Alex Burr
    Memphis, TN
  • Trevor J
    Hmmm! Not sure what to think about that. It is a very large drum. Looks hudson. Are you saying that you can also look up the bendix no.
    Trevor
  • hudsontech
    sorry, don't have the bendix numbers
    Alex B
