Dash Removal?
It isn't necessary to remove the dash to do the work that you want to do. I recently installed a new wiring harness in my '50C6 sedan. It is necessary to lay on your back under the dash for long hours to accomplish this work and that gets real tedious, but I would avoid removing the dash, unless you plan to have the wood graining redone or repainted.0
taking the dash out is simple so not much to worry about I powder coated mine and glued a vinyl cover on top and found it to be easy0
Richard E. .. Did you use a voltage reducer for each gauge, and did you replace every wire on every accessory?0
- 114 Hudson 1916 - 1929
