Splasher Rods?
Unknown
I need a little help. I'm looking for NOS splasher rods for the 212 6 cylinder engine. The part number is 157369. I know I can have someone re babbit them but if I can avoid the cost and the amount of time involved all the better. PM me if you have a lead. No luck with Dale Cooper he only had two. Thanks!
  • Marconi
    Marconi Senior Contributor
    Try Jason @ Vintage Coach. 8am till 5pm Tues. to Sat. 909-823-9168
  • I may have some rods for your splasher engine. I bought some extra rods a while ago. Since i got another 212 for my 41 running I have extra parts. If interested I'll check the numbers. Jim
  • Tried to send you a pm to no avail. Jim
  • I would be interested Jim. Thanks!
  • Geoff
    Geoff Senior Contributor
    What size do you need? Your number is incorrect, the numbers are 157363 and 157364 for the 5" stroke motor
  • I looked in the parts book and you are correct. The rods I pulled out of the engine are all 157369. 1,2 and 4 are right hand and 3,5 and 6 are left. They are all stamped 157369. I just purchased two rods from Dale Cooper and the rods he sent to me are also stamped 157369 they are left hand rods. Could it be some were finished, or semi finished? What I need is 3 right hand rods and 1 left hand rod. Thanks.
  • ottobethere, Ok, I have six rods and pistons 157369, if your interested. Jim
  • ottobethere Since this forum keeps flip flopping I'll give you my ph. no. [716] 826- 7087 JIm
