Stepdown Trunk Rubber Weatherseal
ernie28
ernie28 Expert Adviser
edited October 2012 in HUDSON
I understand there are two styles of rubber used for weathersealing the trunk. Does anyone have an instruction sheet showing what style goes where? I then need to get what I need.
Thanks.
  • raidmagic
    raidmagic Senior Contributor
    I would like to know this as well. Mine has two cuts at the hinges and leaks like a civ.
  • Snailslayer
    Snailslayer Expert Adviser
    you mean Sieve. order online from kgap
  • [Deleted User]
    edited October 2012
    I purchased from K-Gap my trunk weatherseal for my 50 Pacemaker around 20 years ago and it still works fine. It is to be hoped that K-Gap still has this seal available. You may want to check with them first on the availability of the seal material and then send your money to them. My recent experience with them went fine as apparently the items I purchased were in stock.
  • The trunk seal is a common type you can get by the foot if you have a sample for . J C Whitney has it ,
    Roger
  • SuperDave
    SuperDave Senior Contributor
    Yes there are two different kinds. The 54 has the gasket on the lid unlike the 48-53 which is on the body. I have had poor luck getting the replacement gasket to seal on two 49's. I got a seal that was intended to seal the doors on a 56 Dodge four door .It was soft but thicker. Leaks stopped. There was about 6" left after cutting and installing. I didn't have to glue it either. It wasa nice tight fit in the channel. (The Dodge owner said it would not let his doors close properly)
  • StillOutThere
    StillOutThere Expert Adviser
    The Hudson weatherseals for trunk and doors are absolutely NOT universal Whitney and other supplier one size fits all JUNK. Oh sure you can glue that stuff in but in almost every case it is too thick and your trunk or doors will not close properly. Hudson engineered specific seals for every application area and they were extruded or molded to their exacting specifications. K-GAP went to a great deal of time and expense to find mint samples of originals and had extrusion dies made and made again until they were correct. Molds same. Multiple suppliers were employed in California and elsewhere.
  • [Deleted User]
    edited October 2012
    Well that is true but what are we to do now that Kgap has evaporated ? ? I have not even seen them at a national meet since Detroit and then they were there on the last day or two,
    Roger
  • Get in touch with Dr Doug Wildrick. Walt
  • A thicker,bigger seal is glued to the lid to somewhere about 6 or seven inches from the bottom of the trunk going up to the top of lid and then a smaller seal is used for this verticle 6 or 7 inches and the horizonal bottom. I would not rely on K-gap. They will hang you up and take your money,,,....It is a very different set up and if you do not use the correct seals I can see one having opening and closing issues and perhaps leaking.
  • ernie28
    Thanks all for your contributions. I have communicated with K-Gap re this and am just waiting their response.
    Walt, do you have a contact for Dr Doug Wildrick?
    Hotrodman, do you have dimensions for these two types?
  • RL Chilton
    Here's a link for Doug Wildrick:
    http://www.wildrickrestoration.com/
  • I've heard that Doug is taking over Full Line and may have some parts you need. Try his cell 317-847-1720 Or hetdrdoug96@comcast.net Drop the het, it's there to fool computers that pick up mail and send spam and junk. Let me know how you make out. Walt
  • Well you see thats the problem with Kgap you call and wait , and wait , and wait .and do like I did and buy what you need from JC Whitney or Metro. And Yes Dr. Doug the Clutch Guy has been working on getting the Full line going . Give him a call ,
    Roger
